Amelia S Posted August 8, 2014 Share Posted August 8, 2014 Can anyone help us with door hardware? All of the sets listed are empty (when I select them nothing shows up on the door). When I go to manage hardware -> edit, there is all of the data but no symbol, and nothing happens when I click in the symbol box. Same thing when I try to add hardware. I can't select any symbols. I don't really understand how door hardware works vs. all of the normal symbols. Any tips would be greatly appreciated. Thank you!! Quote Link to comment
ChrisA Posted August 8, 2014 Share Posted August 8, 2014 Hi Amelia Does your door hardware tool look like this (see attached) Quote Link to comment
Amelia S Posted August 11, 2014 Author Share Posted August 11, 2014 Thanks for your reply Chris. It doesn't. It looks like this. You can see where yours shows the door hardware symbol and mine doesn't. That's where I'm unable to see or select any hardware. I have the door hardware library in my resource browser though.. Quote Link to comment
Amelia S Posted August 12, 2014 Author Share Posted August 12, 2014 To anyone who is successfully using door hardware: Where in your computer is the Door Hardware.vwx file stored? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted August 12, 2014 Vectorworks, Inc Employee Share Posted August 12, 2014 It should be in Vectorworks2014\Libraries\Defaults\Door - Hardware However, did you do this after installing Vectorworks? http://kbase.vectorworks.net/questions/1170/Vectorworks+2014+Content+Library+Installation I believe you have to install the architectural libraries in order to get door hardware. Quote Link to comment
Amelia S Posted August 12, 2014 Author Share Posted August 12, 2014 Thanks Jim, I did do that when I installed 2014 but I'd really like to avoid doing it again because wouldn't that create duplicates of everything? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted August 12, 2014 Vectorworks, Inc Employee Share Posted August 12, 2014 No, it would overwrite any that were already installed. If you run it again and you still don't get the door hardware once it is finished installing, check with tech@vectorworks.net Quote Link to comment
