Mickey Posted July 17, 2014 Share Posted July 17, 2014 I would like to set some dimension preferences. Things like no fractions, witness lines, style etc. However when I select the dimension tool and click the settings button I only get a dialog box for "chain dimension preferences" No matter what type of dimension I pick this is the only dialog box that opensd. This can't be right. Anyone have the same problem? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 17, 2014 Vectorworks, Inc Employee Share Posted July 17, 2014 Its done within Document Preferences, this should cover it: Quote Link to comment
Mickey Posted July 22, 2014 Author Share Posted July 22, 2014 That was almost helpful. The only thing I want to do is set the Prec: to no fractions as a default, and that's not an option in the dimension standards. SO I have to click that drop down for every dimension. lame Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 23, 2014 Vectorworks, Inc Employee Share Posted July 23, 2014 You can alter that specific setting in the Units settings under Document Settings. Once set, you can save the file as a template and use that for future drawings. Drawings that you already created will have to be modified after the fact. 1 Quote Link to comment
