Viewing 3D poly tile markup in a section viewport
Ive marked up some tiling areas on a 3d model using the 3d poly tool like the image below.
I then take these 3d models and generate a plan, and 4 section viewports, these are rendered in hidden line.
How can i do this so the colored areas in the model show up in the section viewports ?
Ideally id like to avoid using multiple stacked viewports in my sheet layer as they are more fiddly to maintain. Id also like to avoid using the opengl render setting as im not really looking for a rendered image, im just looking to present a line drawing for setting out / calcs for tile areas.
