John Whyte Posted April 10, 2014 Share Posted April 10, 2014 I produce quite a few 3d setting out room drawings which i then take multiple section viewports from as well as a 2d plan. When editing these models i can pan and orbit the drawings in the design layer (in wireframe mode) as needed, this is really quick with no lag, but when i go to my sheet layer and have to update all my section viewports they take a while to update, the background render mode for them is hidden line and the foreground render is none. Is there another render mode (or something else) that i can use to speed this up ? Quote Link to comment
Benson Shaw Posted April 10, 2014 Share Posted April 10, 2014 One thing is to enable the Save Viewport Cache. This holds the render status for VPs which have no changes, which might speed up a whole sheet full of VPs if only a few need the update. It's in File>Document Settings>Document Prefs>Display tab. -B Quote Link to comment
John Whyte Posted April 11, 2014 Author Share Posted April 11, 2014 Thanks Benson, Is there a downside to this - increased file size, increased file loading times when first opening ? Quote Link to comment
Benson Shaw Posted April 11, 2014 Share Posted April 11, 2014 Good question, John. I dunno. Maybe others know about this. Test one of yours and post back. A rendered file saves with a bigger size than the unrendered version, but if you have some things rendered anyway, the cached renders might not change the file size very much. Initial loading comparison with a stop watch could be informative. Another thing is to check that your VPs are showing only the necessary layers and classes. Additional layers or classes may have objects out of the crop = extra rendering effort. -B Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted April 11, 2014 Vectorworks, Inc Employee Share Posted April 11, 2014 It normally does not increase load times noticeably but it will increase file size, dramatically if the viewports are very large or high DPI. The tradeoff is storage space for time spent rendering. Quote Link to comment
