DeSignature
3d-Array
Has anyone found an alternative for a - as far as I know - non-existing 3d-array?
I'm looking for something like:
VAR
: ARRAY [m..n, o..p, q..r] OF
BEGIN
vectorscript can only handle a 2 Dimensional array.
However, structures can provide you with what you are looking for in a slightly different way.
The only downside is that the inner arrays are static, they can't be dynamic.
So ... a few days later:
I am getting n^3 results, just not the ones I was hoping for.
X, Y is OK; Z doesn't seem to work well, so - hoping someone will see what I'm trying to do - I'll just drop some code in here.
PROCEDURE Silver_Constant;
CONST
Psi	= (1 / 2 + Sqrt (23 / 3) / 6) ^ (1 / 3) + (1 / 2 - Sqrt (23 / 3) / 6) ^ (1 / 3);
TYPE
DDD_ARRAY = STRUCTURE
	H	: ARRAY [0..7] OF REAL;
END;
VAR
P, L	: ARRAY [0..7, 0..7] OF DDD_ARRAY;
a, z, n	: LONGINT;
SD		: REAL;
Obj_H	: HANDLE;
FUNCTION Block (p1, p2, l1, l2: REAL): HANDLE;
BEGIN
	BeginXtrd (p1, l1);
		RectangleN (p1, p2, 1, 0, l1, l2);
	EndXtrd;
END;
BEGIN
SD := RealDialog ('Enter the dimensions of the smallest block', '100');
FOR a := 0 TO 7 DO
BEGIN
	FOR z := 7 DOWNTO 0 DO
		BEGIN
		FOR n := 0 TO 7 DO
		BEGIN
			P[a, z].H[n]	:= SD * (SD - (SD * Psi ^ a)) / (SD - (SD * Psi));
			L[a, z].H[n]	:= SD * Psi ^ a;
			Obj_H	:= Block (P[a, z].H[n], P[z, a].H[n], L[a, z].H[n], L[z, a].H[n]);
		END;
	END;
END;
END;
RUN (Silver_Constant);
Edited by DeSignature
(...) just 3D points (...)?
I don't understand your suggestion as the're actualy extruded rectangles, and I couldn't find a 'Draw-Extruded-Rectangle (x1, y1, z1, x2, y2, z2)'-procedure.
There also seems to be a problem with the BeginXtrd-Procedure , allthough, I actualy don't know if this specific problem applies to my situation.
... and I couldn't find a 'Draw-Extruded-Rectangle (x1, y1, z1, x2, y2, z2)'-procedure.
You can create a wrapper function that will create extrudes based on two 3Dpoints:
FUNCTION BlockByBBox (p1, p2: POINT3D): HANDLE;
BEGIN
BeginXtrd (p1.z, p2.z);
	Rect (p1.x, p1.y, p2.x, p2.y);
EndXtrd;
END;
Or something like this:
FUNCTION BlockByBBox (p1X, p1Y, p1Z, p2X, p2Y, p2Z: REAL): HANDLE;
BEGIN
BeginXtrd (p1Z, p2Z);
	Rect (p1X, p1Y, p2X, p2Y);
EndXtrd;
END;
But I don't realy understand what you try to accomplish... With this script, I get somewhat the same result.
CONST
TYPE
	X	: ARRAY [0..7] OF REAL;
	Y	: ARRAY [0..7] OF REAL;
	Z	: ARRAY [0..7] OF REAL;
END;
VAR
P, L	: DDD_ARRAY;
a, z, n	: LONGINT;
SD		: REAL;
Obj_H	: HANDLE;
BEGIN
	BeginXtrd (p1, l1);
	EndXtrd;
END;
BEGIN
FOR a := 0 TO 7 DO
BEGIN
	BEGIN
		FOR n := 0 TO 7 DO
		BEGIN
			P.X[a] := SD * (SD - (SD * Psi ^ a)) / (SD - (SD * Psi));
			P.Y[z] := SD * (SD - (SD * Psi ^ a)) / (SD - (SD * Psi));
			P.Z[n] := SD * (SD - (SD * Psi ^ a)) / (SD - (SD * Psi));
			L.X[a] := SD * Psi ^ a;
			L.Y[z] := SD * Psi ^ a;
			L.Z[n] := SD * Psi ^ a;
			Obj_H	:= Block (P.X[a], P.Y[z], L.X[a], L.Y[z]);
			Obj_H	:= Block (P.X[z], P.Y[a], L.X[z], L.Y[a]);
		END;
	END;
END;
END;
Be aware that you're creating a lot of objects that have the same dimension and position. Is this neccesary?
Maybe if you tel us what the result should be, we could help you better?
Well, exactly that, every block (at the end there should be 83 of them) should have it's unique dimension and co?ridnates.
I'm actualy trying to customize this system, kind of like Le Corbusier's Modulor.
The 2D-part looks like this:
PROCEDURE Silver_Number;
CONST
Psi	= (1 / 2 + SQRT (23 / 3) / 6) ^ (1 / 3) + (1 / 2 - SQRT (23 / 3) / 6) ^ (1 / 3);
VAR
P, L	: ARRAY [0 .. 7, 0 .. 7] OF REAL;
a, z	: LONGINT;
GT		: REAL;
BEGIN
GT := RealDialog ('Smallest Block Dimensions = ', '100');
FOR a := 0 TO 7 DO
BEGIN
	BEGIN
		P [a, z]	:= GT * (GT - (GT * Psi ^ a)) / (GT - (GT * Psi));
		L [a, z]	:= GT * Psi ^ a;
		RectangleN (P [a, z], P [z, a], 1, 0, L [a, z], L [z, a]);
	END;
END;
END;
RUN (Silver_Number);
And yes, of course, we might leave the necessity open for discussion ... but - whatever the result of this discussion - it might help me understand coding vectorworks.
Meanwhile I'll see what I can do with your - much appreciated - suggestions.
Edit:
Had to look really hard for it (at the most obvious place of course):
English Version
Not really sure how I got there, but I'm there:
CONST
TYPE
STRUCTUUR = STRUCTURE
	P, L	: ARRAY [0..6] OF REAL;
END;
VAR
Pos, Len	: ARRAY [0..6, 0..6] OF STRUCTUUR;
Bot, Top	: ARRAY [0..6, 0..6] OF STRUCTUUR;
a, z, n		: LONGINT;
SB			: REAL;
Ext_H		: HANDLE;
BEGIN
SB := RealDialog ('Smallest Block Dimensions = ', '100');
FOR a := 0 TO 6 DO
BEGIN
	FOR z := 6 DOWNTO 0 DO
	BEGIN
		FOR n := 6 DOWNTO 0 DO
		BEGIN
			Pos [a, z].P [n]	:= SB * (SB - (SB * Psi ^ a)) / (SB - (SB * Psi));
			Len [a, z].L [n]	:= SB * Psi ^ a;
			Bot [a, z].P [n]	:= SB * (SB - (SB * Psi ^ n)) / (SB - (SB * Psi));
			Top [a, z].P [n]	:= (Bot [a, z].P [n]) + (SB * Psi ^ n);
			RectangleN (Pos [a, z].P [z], Pos [z, a].P [a], 1, 0, Len [a, z].L [z], Len [z, a].L [a]);
			Ext_H := HExtrude (LNewObj, Bot [a, z].P [n], Top [a, z]. P [n]);
		END;
	END;
END;
END;
If anyone feels like to elaborate on what is actualy happening here, please do.
BeginXtrd works fine and you should use it if you are just creating extrured rectangles, that is if they are extruded on the Z axis. You have to keep it simple. If things are getting too hard, look at it another way...
Edited by Dieter @ DWorks
I'll keep that in mind.
Meanwhile I found out that the code above doens't work properly in a PIO, just because of the following lines
In a PIO this line should be replaced by:
   BeginXtrd (Bot [a, z].P [n], Top [a, z]. P [n]);
   EndXtrd;
