Guest BillV Posted February 24, 2014 Share Posted February 24, 2014 (edited) I would welcome input or comments on this subject. A standard STL file produced some issues when printing on an STL printer (two different brands) Going back basics I put all objects to a single layer and a single class. This works well. I also set polygons to low which speeds up the print process. Has anyone tried any other methods for layers and classes. NURBS has also appeared problematical. Testing has been on a Ricoh printer and a Diamondmine printer. Very economical method for producing a model of a building, For a 22cm long single story small home the material cost to print is $US1.91 Edited February 24, 2014 by BillV Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 25, 2014 Vectorworks, Inc Employee Share Posted February 25, 2014 (edited) I often find if I open and repair my exported STL files from Vectorworks in the free netfabb basic utility, I get much better print results: http://www.3daddfab.com/blog/index.php?/permalink/Automatically-Repair-STL-Files-in-2-Minutes-with-netfabb.html Normally I only need to use the Automatic repairing of STLs, but there is a more in-depth manual method detailed here as well: http://3daddfab.com/blog/index.php?/archives/11-Use-netfabb-to-Manually-Repair-STL-Holes,-Edges-and-More.html It is capable of confirming that objects are manifold as well as clearing out self-intersecting solids and coplanar surfaces. Edited February 25, 2014 by JimW Quote Link to comment
Kevin McAllister Posted February 25, 2014 Share Posted February 25, 2014 I've had good success exporting solids from VW as STLs. Any NURBS in a file need to create a closed shape or they will cause problems because they have no thickness. As you say putting things on a single layer is good practice but things seem to behave ok as long as the layers are all in the same scale and Unified View is on. I haven't had any issues with multiple classes. Setting polygons to low is ok if all your shapes are planar but I wouldn't recommend it if you have curved surfaces. As Jim says, you should investigate netfabb if you haven't already. The free version is very capable. Kevin Quote Link to comment
Guest BillV Posted February 26, 2014 Share Posted February 26, 2014 (edited) Jim / Kevin Thanks for the reply. The software you recommended is excellent and a great help in making sure it all works before committing to the printer. I have also been able to convert STL objects to DXF and import them into Vectorworks to combine with designs I am working on. Edited February 26, 2014 by BillV Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted April 2, 2014 Vectorworks, Inc Employee Share Posted April 2, 2014 For others that may come across this: http://kbase.vectorworks.net/questions/1124/Improving+STL+File+Export Quote Link to comment
Guest BillV Posted April 29, 2014 Share Posted April 29, 2014 The Siemens Parasolids engine creates a number of triangulations when exporting to STL. For those who have Cinema 4D you can export from VW to C4D and use the "untriangulate" command to resolve this , then export as STL from C4D. Quote Link to comment
Guest BillV Posted September 21, 2015 Share Posted September 21, 2015 Jim I have been doing some work with Fuji Xerox and they have shown me output from this printer; http://www.3dsystems.com/3d-printers/professional/projet-660pro The printer is able to print in any range of colours and will print textures based on the image used in the drawing for that texture ie wood or brick. However the files it requires are .wrl files which we do not support. I presume there is an awarenes of this at NVI . I will send the files separately as the "add file" does not support this file type. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 21, 2015 Vectorworks, Inc Employee Share Posted September 21, 2015 Its more likely that .X3D will replace .WRL, however I am not sure. Currently we don't have any 3D printers here capable of color, nor do I personally, so there has not been any great push in that direction so far. However, I have submitted a number of wishes related to this and I will add this post to them. Quote Link to comment
Guest BillV Posted September 23, 2015 Share Posted September 23, 2015 (edited) Jim I have attached 3 images of the full colour print. 6 inches wide 3 inches deep 1.5 inches high NZ$ Cost $240 US$ Cost $150 Edited September 24, 2015 by BillV Quote Link to comment
