Bpatt Posted January 21, 2014 Share Posted January 21, 2014 I have a master file with a A-WALL-FIRE class. It is referenced into a design layer in my floor plan file. Then i have an enlarged plan viewported from the design layer. I need the A-WALL-FIRE class off in the enlarged plan. I have tried everything i can't get it to turn off in the viewported enlarged plan. I can turn it off in floor plan however i need the floor plan to have the class shown. I have turned the class to make all attributes by class. Can anyone help? Barbie Quote Link to comment
SonnyLuong Posted April 16, 2014 Share Posted April 16, 2014 Did you actually checked off that class visibility in the viewport dialog box? Make sure you check the class and layer visibility within the viewport dialog box. If I understood what you were doing, you were not separating A-Wall-Fire Class from the floor plan class. You can set up many different classes for objects on the same layer. Quote Link to comment
