CLASS VISIBILITY ISSUE
Bpatt
I have a master file with a A-WALL-FIRE class. It is referenced into a design layer in my floor plan file. Then i have an enlarged plan viewported from the design layer. I need the A-WALL-FIRE class off in the enlarged plan. I have tried everything i can't get it to turn off in the viewported enlarged plan. I can turn it off in floor plan however i need the floor plan to have the class shown. I have turned the class to make all attributes by class.
Can anyone help?
Barbie
  • 2 months later...
Did you actually checked off that class visibility in the viewport dialog box? Make sure you check the class and layer visibility within the viewport dialog box. If I understood what you were doing, you were not separating A-Wall-Fire Class from the floor plan class. You can set up many different classes for objects on the same layer.
