Kevin C Posted January 20, 2014 Share Posted January 20, 2014 I am trying to create a housing development layout model using Renderworks 2014 with the houses referenced in from individual VW files. Can anyone tell me why the resolution of the render is so poor. Each of the house files render absolutely perfectly, but when the files are referenced into the development layout (with all the roads, hard and soft landscaping etc) the resolution of the render (whether in the main design layer or a sheet layer) is abysmal. Please help - Client is not happy with the output, and am unable to say why I am unable to produce a suitable presentation drawing. Thanks in advance: Kevin Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted January 20, 2014 Vectorworks, Inc Employee Share Posted January 20, 2014 Could you post a few sample images comparing the rendering in the source file to the rendering when referenced? It shouldn't be reducing quality simply because its referenced in, most likely this is a setting in the file or with a specific viewport we can correct. Quote Link to comment
Kevin C Posted January 20, 2014 Author Share Posted January 20, 2014 Jim, I have attached two files. 1st file - "fast renderworks" from the design layer of the root file 2nd File - "fast renderworks" from the main drawing. The output was meant to be a "realistic render - but the two files show well enough the difference between the original and referenced file. BTW - There are 11 house types referenced into the main drawing with 78 referenced viewports to create the whole drawing. I have attached a dropbox link to the two files. https://www.dropbox.com/sh/x2ruc1i5gx1qsy8/vMBqIYoGkF Thanks, Kevin. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted January 20, 2014 Vectorworks, Inc Employee Share Posted January 20, 2014 What is the DPI of the sheet layers these viewports reside on? If you render in Final Quality Renderworks instead, are the results comparable and still worse on the reference, or do they more closely match in quality? Do you see the same quality issues when rendering in OpenGL with detail set to Very High? If you reference that same file into a new blank file, create the viewport and render, does it suffer from the same loss in quality? Quote Link to comment
Kevin C Posted May 7, 2014 Author Share Posted May 7, 2014 Solution Found. Haven't been on the forum for a while, but I found the problem - and sorted it. It has nothing to do with the rendering whatsoever, it was the wall construction. I had a fully detailed wall make-up specified in the houses and the breather membrane was the item which was causing the problem. It seems that VW keels over if each of the components does not have minimum thickness. Normally you would put a thickness of 0.1mm for membranes (so that they don't add to the overall wall thickness), but VW requires a thickness of at least 1.0mm or something goes wrong. Kevin. Quote Link to comment
