vlamar Posted January 15, 2014 Share Posted January 15, 2014 I usually make presentations from sheet layers. Now i prepared the camera view in model layer. I want to get just the same picture in sheet layer. When I try to make viewport fron camera view in sheet layer, I get an effect of double lighting un layer, all colores changed. Another question: earlier I made viewport in model layer by using rectangle tool and translate it to viewport. Now when I try to use rectangle tool, i get some rectangle in working plane, I can't use it for view choosing. I work now with VW-2013 on 64 bit computer,8Gb Thank you Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted January 15, 2014 Vectorworks, Inc Employee Share Posted January 15, 2014 Second question first: With the Rectangle tool active, change your Plane mode in the view bar to "Screen" and youll be able to draw as you want with that tool. This explains the Plane system in more detail: http://kbase.vectorworks.net/questions/1086/Working+with+Screen+and+Layer+Planes For the double lighting, please send me that file at tech@vectorworks.net and we can take a look. Quote Link to comment
