vlamar
20 -
Reputation
0 NeutralPersonal Information
Occupation
architect
Hobbies
art@photography
Location
israel
symbol with data display
vlamar replied to vlamar's question in Wishlist - Feature and Content Requests
It seems very important the ability to create symbol, that display the point coordinates. And parametric frame with coordinate scale on their sides. I draw rectangle and get the frame with real coordinates of the plan. Very useful in everyday work
Hello/ I build two terrain models, one for existing topography and one for project. Is it possible to get cuts and fills calculation from these models? For instance, by converting models to solids? Thanks
I usually make presentations from sheet layers. Now i prepared the camera view in model layer. I want to get just the same picture in sheet layer. When I try to make viewport fron camera view in sheet layer, I get an effect of double lighting un layer, all colores changed. Another question: earlier I made viewport in model layer by using rectangle tool and translate it to viewport. Now when I try to use rectangle tool, i get some rectangle in working plane, I can't use it for view choosing. I work now with VW-2013 on 64 bit computer,8Gb Thank you
There is a language bug in VW2008 for right-to left languages, for instance-hebrew. All words you input in data area , you see in back direction. It looks like "book a read I" instead of "I read a book" in english. In VW-11 it was correct.
Sometimes acad drawers send files in english units instead of metric. If you have autocad you may change it in Units directory, or ask from other companies. Xref files you can not see, ask to send them separately, or to bined into the file
I finded in printing forum the GDI in peferences - now it is possible to print. What is GDI? I hope to find any desision for hebrew. Also in callouts and symbols with data. Words (not letters in the word) changes the direction one after another. Sorry for my english explanations
I've just upgraded to Designer 2008. The last years I printed to PDF all files. Now when I print - I got the blank page. When I try to export PDF I get all hebrew text upside, like in mirror. I tried to print to HP plotters, without succes - get error. I work on PC, winodwsXP, 1G memory. I know the programm from Minicad 3. Help me please
Thank you Grant - it seems to me not right to import the same image 2 times (one-for image, and one- for texture). I have a lot of images in my computer, I don't like to find it some times.
Thank you, but this way you may only create new texture from other texture. I am user from Minicad3, but I don't know the way
Are there any possibility to transform image to texture and texture to image? (without out applications) It's very usefull. Thank you
Colour not displayed properly as to Class.
vlamar replied to APE Design Ctr's topic in General Discussion
Did you select "use at creation"box in class assignment? -
Styles are classes atributes, that you may change (open classes, double click on class to select it, attach textures to the class, select"use in creation"box. It's very good idea to use styles for big projects espetially
Thanks, I've already found a problem, I didn't put custom options for render, there are not selected by default
I have to add: VW industry collection+RW for WindowsXP, Pentium-3 1300, 256MB
