I would like to see the introduction of an option that allows the offset (both parallel and at right angles to the frame) of the trim.
The main reason being that in these parts it is common to use sheet metal trims and sills:
or wooden plank trims:
Currently it is almost impossible to get these details to look correct in the native window/door tool, however with the functionality suggested above it should be possible.
VincentCuclair
Edited by Vincent CLink to comment
1 answer to this question
