Assembly Posted December 10, 2013 Share Posted December 10, 2013 How can I bulk change a call out tool?. Find and replace text does not work. Updating the database does not work. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 11, 2013 Vectorworks, Inc Employee Share Posted December 11, 2013 You can modify multiple callout objects at the same time. I think the easiest way would be to use Select Similar or Custom Selection to get all the callouts selected, then simply edit what you want to in the object info palette. Or click Edit Note at the bottom of the OIP to change the actual text. Quote Link to comment
Assembly Posted December 12, 2013 Author Share Posted December 12, 2013 (edited) How do i select 2 different call out objects inside 2 different viewport annotations?. How do I select 2 call outs on different sheet layers? Edited December 12, 2013 by Assembly Quote Link to comment
