Call Out tool database change
You can modify multiple callout objects at the same time.
I think the easiest way would be to use Select Similar or Custom Selection to get all the callouts selected, then simply edit what you want to in the object info palette. Or click Edit Note at the bottom of the OIP to change the actual text.
