Info palette not working after referenced DWG import
Hi,
as the topic says - the Info palette is not working directly after importing a dwg file as a referenced file.
The buttons for advanced properties layer and classes are not responding. Some parts of the info palette are grayed out...
Closing the info palette and reopening solves the problem. Also clicking with the right mouse button on the drawing and choosing "edit properties" brings the info palette back to work.
Is that a known issue?
I tried this with several dwg files...
VW2014 SP1 Mac OS 10.8.5
screenshot of the info palette...
Info palette
I do not see this same behavior with a number of tested DWGs. Are all DWG files doing this for you or only one/a few?
If it is happening only with one or a few DWG files, make sure to contact tech@vectorworks.net with those files and we can have a look.
Otherwise, you may want to backup and reset your preferences with Vectorworks closed:
http://kbase.vectorworks.net/questions/1099/Resetting+Vectorworks+Preferences
  • 3 weeks later...
  • 10 months later...
