ossosso
Model UVW mapping question
Hi everybody!
I'm new in this forum, but I'm also new in Vectorworks.
My target in this moment is to better apply UVW map to a model inside Vectorworks.
In my workflow I model an object into Rhino and then import the .3dm inside Vectorworks.
As we know a nurbs surface doesn't need unwrap process 'cause the surface yet has UV coordinates. But sometimes it isn't enough for a nice result, under this point of view Rhino offers the possibility to apply a common "Box / Cylinder / Sphere" uvwmap to the object, overwriting the normal UV surface coordinates.
When I export the .3dm this feature isn't saved in the file and so Vectorworks open the model with normal uv coordinates.
I simply want to know if inside Vectorworks is possible to apply a Box/Cylinder/Sphere uvwmap.
Thanks a lot!
