Marc Posted September 14, 2002 Share Posted September 14, 2002 Interested to know what line thicknesses people are using out there. I'm just using a crapy little epson on a4 size paper and I get no difference from .03mm to .15mmanyways I found a cool website that explains the whole paper size issue thing. It's a little hard to find the part about pen sizes so here's what he recomends: .13.18.25.35.50.70it's all sq rt of 2 stuff.Hope it helps hope it's interesting.I'm trying to make this link work! arggggg [ 09-15-2002: Message edited by: Marc ]=http://www.cl.cam.ac.uk/~mgk25/iso-paper.html]web page [ 09-15-2002: Message edited by: Marc ] http://www.cl.ac.uk/~mgk25/iso-paper.html [ 09-15-2002: Message edited by: Marc ] Quote Link to comment
Carl Burns Posted September 15, 2002 Share Posted September 15, 2002 .07, .13, .25, .50, 1.0 mm I like having line weights that are 1:2, so perceptibly different (for architectural drawing). The printer: HP430. The manual says .13mm is the smallest line, but in fact it gives a lighter line also, the .07mm, just by thinning out the dots I suppose. similar website: http://www.archivebuilders.com/aba006.html - Carl [ 09-15-2002: Message edited by: Carl Burns ] [ 09-15-2002: Message edited by: Carl Burns ] Quote Link to comment
Marc Posted September 15, 2002 Author Share Posted September 15, 2002 Finally it worked.Anyways... the whole reason about the sq root of 2 is that when you reduce or enlarge you will have equivalent line weights. That is to say if you are drawing with say a .13 on A4 and you enlarge to A3 you can keep drawing with .18 and so on. Later skatersM Quote Link to comment
