domer1322 Posted February 25, 2013 Share Posted February 25, 2013 If my brick veneer walls are horizontal or vertical (in plan) then the brick veneer component hatch is correctly at a 45 degree angle to the wall and it looks good. However, when the walls are at an angle, the hatch is no longer at a 45 deg angle to the wall, and if the wall is at a 45 deg angle, then the hatch becomes straight lines, parallel with the wall. Is there a way to make the component brick hatch always be at a 45 deg angle to the wall ? Quote Link to comment
Dieter @ DWorks Posted February 25, 2013 Share Posted February 25, 2013 Edit the hatch, then check the option to rotate in wall. Quote Link to comment
