STIXBUILT Posted January 30, 2006 Share Posted January 30, 2006 WHEN I EXTRUDE ALONG A PATH, THE OBJECT I AM EXTRUDING ALWAYS CENTERS ON THE PATH. HOW CAN I GET MY EXTRUDED OBJECT TO OFFSET TO ONE SIDE OR THE OTHER OF MY PATH LINE? Quote Link to comment
mike m oz Posted January 30, 2006 Share Posted January 30, 2006 Double click on your Extruded Along Path object and choose to Edit the Profile. You will be able to relocate the profile to where you eant it in relation to the Path - this is at the intersection of the two dotted lines. Quote Link to comment
STIXBUILT Posted January 30, 2006 Author Share Posted January 30, 2006 I CANNOT GET EDIT PROFILE TO COME UP,IS THIS IN THE OBJECT INFO PALLET UNDER CHANGE VERTEX OR AM I WAY OFF BASE HERE? Quote Link to comment
mike m oz Posted January 30, 2006 Share Posted January 30, 2006 Stixbuilt: - Draw your path and your object and Extrude Along Path. - Select the resulting object. - Either Double click on it or Select Edit Group on the Modify menu (Organise menu in earlier versions) or Right Click on it and choose Edit from the Contextual Menu. - In the dialog box which opens up you can choose to either edit the path or the profile. - select profile and move it to where you want it to be in relation to the path origin (intersection of the dotted lines). You can also Reshape the Path using the 3D Reshape Too [ 01-30-2006, 11:28 AM: Message edited by: mike m oz ] Quote Link to comment
STIXBUILT Posted January 31, 2006 Author Share Posted January 31, 2006 mike m oz: Thanks for recognizing my novice abilities the step by step info did the trick. I'm on a Mac so I used the Edit Group method you explained. Next project how to design custom raised panel doors for cabinets that can be sized while staying constrained. thanks again Quote Link to comment
Kevin Posted January 31, 2006 Share Posted January 31, 2006 Thanks Mike. I did not know about this feature. Quote Link to comment
