pytld Posted October 6, 2012 Share Posted October 6, 2012 (edited) I tried ganging a couple of instruments. I can gang by channel, dimmer, or circuit. If I gang by dimmer, the channel has to be ganged too, since they're using the same dimmer, but VW doesn't gang the channel along with the dimmer. If I try to gang the channel separately, it makes a mess of things since each is ganged separately. (By extension, if I gang by circuit, the dimmer and channel must also be ganged.) How does one gang so that only one set of ganging lines is displayed and the channel is put by the dimmer? When three-fer'ing with the tool, it displays two copies of the channel or dimmer that is three-fer'red. How do I get it to display only one? It looks like the ganging tool is not used much. What do people do instead? Edited October 7, 2012 by pytld Quote Link to comment
