confusedone 0 Posted September 19, 2012 Right now, I have created a model all be it not 100%. I have cut a section through the model and set the cut as the working plane... Viewed the working plane and then created a view port to view the section / elevation on a sheet layer. I then work on the mode, go to look at the changes in the section to make sure I have the right setting etc. To do this I have to open up the sheet layer - enter the design layer to view the section - update the section view port (this sometimes updates and sometimes doesn't) - when it doesn't update in the view port I have to exit to the sheet layer and low and behold if I update it in there the changes appear. This is completely random and there has got to be a better way of working in sections. Any suggestions would be welcome.. Live sections would be a good idea. Thanks Quote Share this post Link to post
Joe-SA 24 Posted September 19, 2012 Something doesn't seem right about your initial setup for your section. From your model, choose 'Create Section Viewport'. Place the section viewport on your desired Sheet Layer.(not a Design Layer) It sounds like you might be creating a Design Layer Viewport on a Design Layer and then linking that to a Sheet Layer Viewport. It appears you have a DLVP inside a SLVP. The intermediate step is not needed if the desired result is a section drawing on a sheet layer. Hope this helps. Joe Quote Share this post Link to post
