pscbimmer Posted July 15, 2002 Share Posted July 15, 2002 Half the time when I adjust line weights from real thick to thin the line stays looking thick. The attributes palette shows the line weight is thin when I click on the line, but the drawing does not. Any Suggestions? Quote Link to comment
Matthew Giampapa Posted July 15, 2002 Share Posted July 15, 2002 If you double click on the Pan tool (Hand in 2D tools pallet) does the line change to the correct appearance? If so, you should update your video drivers to a more current version. Otherwise, make sure you don't have another (thick) line overlapping the original or something like that. The "Zoom Line Thickness" preference will also play a role in how lines appear. You may want to try changing this setting to your liking. Matthew GiampapaNNA Technical Support Quote Link to comment
pscbimmer Posted July 15, 2002 Author Share Posted July 15, 2002 None of the suggestions have worked. I did notice that the attributes palette has different options for the lines that did get thinner than the lines that stayed thick. For example, when I click on the lines that did change line weight the fill style is grayed and I am unable to use it. The rest of the palette works. When I click on the lines that did not get thin, the fill style is useable, but the line endpoint toggle, line start point toggle, and line endpoint style are grayed and unuseable. Quote Link to comment
Matthew Giampapa Posted July 15, 2002 Share Posted July 15, 2002 Hmm... you may not have a line object selected. Look at the top of the object information pallet on the shape tab. That should always indicate the "type" of the currently selected object. (This will be above the class and layer settings) Matthew GiampapaNNA Technical Support Quote Link to comment
pscbimmer Posted July 15, 2002 Author Share Posted July 15, 2002 I'm using VW Spotlight and the lines than don't want to show the change of lineweight are light position objects. I don't know why they won't show a change lineweight though. Is it because they are objects? If it says the line weight is changed will it print in the new lineweight or in the original when the object was created? Quote Link to comment
