Tom Klaber Posted April 19, 2012 Share Posted April 19, 2012 I have discovered that if you have an arrow head selected as "on" as a default drawing setting (when nothing is selected) and then change the default to "Class style" the arrow will be stuck on. Everything drawn hence forth will have an arrow despite the fact that is no longer the setting. The only way to change it is to go back to the arrow that was perviously selected - turn it off - then go back to class styles. A little thing - but causes some annoyances. Quote Link to comment
