L+K Posted May 30, 2002 Share Posted May 30, 2002 When working with sheets in a file, is there a way to know which sheet is the active sheet w/o going to the bottom left arrow and actually selecting the sheet? Quote Link to comment
Matthew Giampapa Posted May 30, 2002 Share Posted May 30, 2002 Currently there is no such method. If you are using a script pallet to change sheets. That should keep the last one you switched to selected. Try going to the windows menu -> script pallets -> saved sheets. Matthew GiampapaNNA Technical Support Quote Link to comment
