nobass Posted May 10, 2002 Share Posted May 10, 2002 Hi all How does one change the internal accuracy(under "page"-"units"? thanks Quote Link to comment
Matthew Giampapa Posted May 10, 2002 Share Posted May 10, 2002 Nobass, This is a dynamic factor determined by the scale of all your layers, and the distance of objects from the center of the drawing area. To get more accuracy out of the program, you can make all of your layers closer in scale to each other or remove extraneous objects from the far reached of the drawing area. (This happens a lot with sloppy dxf/dwg files that have garbage left on the edge of the page. To check for this, make all classes and layers modifiable, and select all and use the fit to page command) Or as an alternative, you can upgrade to VectorWorks 9. It has an expanded floating point coordinate system which eliminates this particular issue completely. Matthew GiampapaNNA Technical Support Quote Link to comment
