Cadplan Architecture Posted October 29, 2011 Share Posted October 29, 2011 I'm just setting up a new worksheet document so that I don't use anything from previous version of Vectorworks. I have drawn a 300mm cavity wall in my 1:100 layer but when pasted into a 1:50 layer it reverts to a 300mm thick plain wall without any separate components. All the classes are visible, I can't figure out why it's happening, I'm probably missing something really simple. any ideas? thanks AJ Quote Link to comment
Monadnoc Posted October 29, 2011 Share Posted October 29, 2011 (edited) Did you check under Document Preferences if the "Hide Details when Layer Scale is <= 1:" is not selected (or set to 1:50 or lower)? If it's in a Viewport, make sure "Show Wall Components" is selected under Advanced Properties. Monadnoc Edited October 29, 2011 by Monadnoc Quote Link to comment
Cadplan Architecture Posted October 31, 2011 Author Share Posted October 31, 2011 I'm almost too embarrassed to say but for some reason every time I selected the pasted into layer the view changed away from Top/Plan. All seems to be well now that I've keyed in #5! Quote Link to comment
