James Milkey Posted April 21, 2002 Share Posted April 21, 2002 This has been a problem on both platforms but I've been trying to Search/Replace text "LD-12-1" to "LD-12-1-##" and when I do it crashes the computer or at least the program. I've found a way around it by Replacing "LD-12-1" to "LT-X" and then to "LD-12-1-##" and that works quickly and the program doesn't seem bothered by it. I wonder if it's simply because I'm only adding text to the Search/Replace string. Quote Link to comment
Matthew Giampapa Posted April 22, 2002 Share Posted April 22, 2002 James, This is currently an outstanding bug (#25573 to be exact) It should only happen when replacing a search string with another variant of that string. The workaround you discovered is the same as what we have on file. Replace the string with a totally different string, then replace that with the desired information. This should be fixed in a later release. Matthew GiampapaNNA Technical Support Quote Link to comment
