Tom7 Posted August 17, 2011 Share Posted August 17, 2011 I am new to Vectorworks and am not able to get the autojoin junction to work. I have selected "autojoin" from the quick prefs and have also gone to tools>options>vectorworks preferences and enabled autojoin but the walls are not autojoining! I have just begun a new floor plan and am using the int 2x4 gyp bd 1/2 style. Also, I notice that at every right angle of my walls there is a diagonal line present. This line was not present when I did the architectural tutorial PDF. Can anyone help me out, please? Tom Quote Link to comment
mar schrammeyer Posted August 17, 2011 Share Posted August 17, 2011 You are maybe working in 3D top view instead top plan, you will see a line on the joint then, why auto join is not working i cannot say if everything is ticked Quote Link to comment
taoist Posted August 17, 2011 Share Posted August 17, 2011 I just tried in VW 2008 Architect and it works fine. I have no diagonal line insert though. Will keep playing to see if I can re-create your problem even though I do not have VW 2011 yet. taoist Quote Link to comment
taoist Posted August 17, 2011 Share Posted August 17, 2011 I found out that if you have end caps set to start or both, the diagonals show in each corner. I can't recreate your problem. No matter what I set my Wall Preferences > Insertion Options the wall auto join. taoist Quote Link to comment
Tom7 Posted August 19, 2011 Author Share Posted August 19, 2011 Thanks for the help. I'm not sure what I clicked or what change I made, but the autojoin began working as I wanted shortly after I created this post. -Tom Quote Link to comment
