myf
change hatch fill via script
Hi,
I want to select object with specific hatch fill
and change the fill of the selected objects then.
If possible with all objects in drawing
(including groups and symbols)
How can I reach this via vectorscript?
thanks
Here is a peace of code,
I can select the objects with the specified hatch,
but i don't now how to set the hatch then (see Set????)
and if it works, how to select the hatch in an interactive way...
PROCEDURE CHHatch;
PROCEDURE EditHatch( ObjHand : HANDLE );
BEGIN
Set?????(ObjHand, ??? 'Hatchname');
ResetObject( ObjHand );
END;
BEGIN
ForEachObject( EditHatch, HFI='Hatchname' );
ReDrawAll;
END;
RUN(CHHatch);
thanks for help
Thank You!
I have to try out.
How do you come from Foreachobj
to SetVectorfill,
it doesn't work like my first example.
Just works with SetLW...
I always get a "Function"-ERROR,
how to use this Functions instead of Procedures
Edited by myf
A wild guess, but maybe you forgot to assign the boolean to the function?
This example will replace the hatch "Old Hatch" (on every object that has that hatch) with "New Hatch".
PROCEDURE CHHatch;
VAR
	bool : BOOLEAN;
BEGIN
	bool:=SetVectorFill (ObjHand, 'New Hatch');
END;
BEGIN
ForEachObject( EditHatch, HFI='Old Hatch' );
END;
RUN(CHHatch);
Wow,
I don't know why it works,
but it works fine
Dank je wel!
I found this example-code at
http://www.nemetschek.net/support/custom/vscript/example.php
to choose an Hatch,
but I have no idea to get it combined the my ChHatch-Script above and get two times this window to choose the old Hatch and then the new one.
Can someone explain me how to combine (these) scripts and get the VARs from one to another?
PROCEDURE ImagePopTest;
VAR
gHatchList:dynarray[] of STRING;
gHatchCount,gDlogID,gDlogResult : INTEGER;
gHatchChoice : STRING;
gOKdlog : BOOLEAN;
FUNCTION BuildHatchList:INTEGER;
VAR temp_i,temp_cnt:INTEGER;
BEGIN
temp_cnt := 0;
FOR temp_i := 1 TO NameNum DO IF (getobject(namelist(temp_i)) <> NIL) & (gettype(getobject(namelist(temp_i))) = 66) THEN BEGIN
	temp_cnt := temp_cnt +1;
	allocate gHatchList[1..temp_cnt];
	gHatchList[temp_cnt] := namelist(temp_i);
	END;
BuildHatchList := temp_cnt;
END;
FUNCTION Define_Dialog: INTEGER;
VAR dialogID,i : INTEGER;
BEGIN
dialogID := CreateLayout('Hatch Picker Dialog',True,'OK','Cancel');	CreateStaticText(dialogID,4,'Select the Hatch:',-1);
CreateControl(dialogID,5,10,'',0);
SetFirstLayoutItem(dialogID,4);
SetBelowItem(dialogID,4,5,0,0);
Define_Dialog := dialogID;
END;
PROCEDURE Drive_Dialog(VAR item:LONGINT; data:LONGINT);
VAR temp_i,i:INTEGER; temp_s:STRING; result:BOOLEAN;
BEGIN
CASE item OF
	SetupDialogC: FOR i := 1 TO gHatchCount DO temp_i := InsertImagePopupObjectItem(gDlogID,5,gHatchList[i]);		1:gHatchChoice := GetImagePopupObject(gDlogID,5,getImagePopupSelectedItem(gDlogID,5));
	END;
{of CASE}
END;
BEGIN {MAIN}
gHatchCount := BuildHatchList;
gDlogID := Define_Dialog;
gOKdlog := VerifyLayout(gDlogID);
IF gOKdlog THEN gDlogResult := RunLayoutDialog(gDlogID,Drive_Dialog);
IF (gDlogResult = 2) THEN alrtdialog('You canceled') ELSE alrtdialog(concat('You chose ',gHatchChoice));
END;Run(ImagePopTest);
Thank You!
This one would work.
I don't have the time now to explain the variable part though, sorry :S...
But ask along and i'm sure somebody would explain it how it works.
VAR
gHatchChoiceOld,gHatchChoiceNew,gCrit : STRING;
gOKdlog : BOOLEAN;
{Subfunction BuildHatchList}
VAR
BEGIN
	temp_cnt := 0;
	BEGIN
	END;
END;
{End Sub}
{Subfunction Define_Dialog}
VAR
BEGIN
	CreateStaticText(dialogID,4,'Select the old Hatch:',-1);
	CreateStaticText(dialogID,6,'Select the new Hatch:',-1);
	CreateControl(dialogID,7,10,'',0);
	SetBelowItem(dialogID,5,6,0,0);
	SetBelowItem(dialogID,6,7,0,0);
END;
{End Sub}
{Subprocedure Drive_Dialog}
VAR
	temp_i,i:INTEGER;
	temp_s:STRING;
	result:BOOLEAN;
BEGIN
	CASE item OF
		SetupDialogC:
		BEGIN
			FOR i := 1 TO gHatchCount DO temp_i := InsertImagePopupObjectItem(gDlogID,7,gHatchList[i]);
		END;
		1:
		BEGIN
			gHatchChoiceOld := GetImagePopupObject(gDlogID,5,getImagePopupSelectedItem(gDlogID,5));
			gHatchChoiceNew := GetImagePopupObject(gDlogID,7,getImagePopupSelectedItem(gDlogID,7));
		END;
	END;
END;
{End Sub}
VAR
	bool : BOOLEAN;
BEGIN
	bool:=SetVectorFill (ObjHand,gHatchChoiceNew);
END;
{End Sub}
{MAIN}
BEGIN
BEGIN
	gCrit:=ConCat('HFI=',Chr(39),gHatchChoiceOld,Chr(39));
	ForEachObject(EditHatch,gCrit);
END;
END;
Run(ImagePopTest);
Another time "WOW"
you are great,
i think i will need monthss to understand that,
but i will try.
Thanks to your nice written code,
i can understand at least a little bit...
Dank je well
mika
