Assembly Posted May 21, 2011 Share Posted May 21, 2011 FUNCTION BuildResourceList( TYPE :INTEGER; folderIndex :INTEGER; subFolderName :STRING; VAR numItems :LONGINT) : LONGINT; Is there a similar function that allow a full custom path?. I'm looking for a function that does exactly what BuildResourceList does with out the folder index. I'd like to build a list of symbols in a File located on a network hardrive. BuildResourceList defines the starting path. Is there one? Has anyone developed there own?. If not then does anyone know how to get access to the resources of an external file from VS?. Quote Link to comment
maarten. Posted May 23, 2011 Share Posted May 23, 2011 It is not possible according to the VS Language guide (see "What VectorScript Can't Do") The only thing i can think of is working with favourites. When you add that file on your server to your favourites (in the resource browser), a shortcut to that file will be added to your library and you can make a list of that with BuildResourceList. Quote Link to comment
