ChrisA Posted May 10, 2011 Share Posted May 10, 2011 Up until now i have done a work around on this but I am now taking a few minutes to figure out a better way, with help of course. I would like to: Create a wall at 8'- have it render with siding and generate accurate materials take-off. Create a slab at 1'0" - that the outside face renders with siding. If I use model set up to create floor and slabs and I have it set from FF to FF. My take offs are all wrong and the stud heights are for a 9' wall. But they render correctly(with the siding covering the slab). if I set my layer height manually I get the right take-offs but I can't have the siding render on my band boards. In the real world I like to run my sheathing to the top of the wall below, Completely covering the bands and plates, creating a tighter envelope. Right now i just show this detail using a 2D drawing on a sheet. I hope this makes sense. I will be in and out of the office all day so i apologize if I don't respond right away. thanks C Quote Link to comment
Jeffrey W Ouellette Posted May 10, 2011 Share Posted May 10, 2011 Hi Chris, What you are looking for is the ability of wall components to wrap around/down the edge of the slab. This was introduced in Vectorworks Architect 2011. Quote Link to comment
ChrisA Posted May 10, 2011 Author Share Posted May 10, 2011 thanks Jeffery that is exactly what I am going for. So I am SOL until I upgrade i guess? C Quote Link to comment
