Anthony Reilly Posted October 13, 2010 Share Posted October 13, 2010 I'm working on a light plot. I have selected a circle around the channel. If I hover over the area where the circle is, I can see a dashed outline of the container. I can also see dashed outlines of other containers I selected in the Label Legend Manager, but I can't make them visible in the drawing. All of the data is there, just not the containers. I also looked at my classes to see if they are visible and in the Object Info Palette. Suggestions please. thank you. Guy aka Anthony Quote Link to comment
MattG Posted October 13, 2010 Share Posted October 13, 2010 I would do the following Go to your navigation first and be sure all your "label" classes are on. I would then be sure you have a label legend assigned to all instruments you are hoping to see this with. Be sure your labels are in the proper place on the instruments in the label legend manager. Refresh all instruments if still nothing is happening check your resource browser and in the container folder edit the symbol labeled circle or whatever container you are not seeing. Be sure the geometry shows up there and that the attributes for the line weight are what you want. After that I am out of suggestions. upload a screenshot or the file for more help. Matt Quote Link to comment
Anthony Reilly Posted October 13, 2010 Author Share Posted October 13, 2010 Ended up editing properties [like you said] in the Resource Browser. Thanks much! Quote Link to comment
