JSiegel Posted September 26, 2010 Share Posted September 26, 2010 Hi All, Please see the attached screen shot. The image was done w/: 1. CRW 2. 2 point lights 3. Curve detail tried both high & low 4. Ray traced shadows 5. No Auto exposure 6. No Final Gather 7. At 300 & 600 dpi What do I need to adjust to get the fascia/soffit detail to read correctly rather than the blurred jagged mess I am getting. Thanks, J Quote Link to comment
Jonathan Pickup Posted September 26, 2010 Share Posted September 26, 2010 I could only see one image in the download. was this image captured form the screen, or exported from Vectorworks? Quote Link to comment
JSiegel Posted September 27, 2010 Author Share Posted September 27, 2010 This was a screen capture from an image .tiff file exported from Vectorworks. PNG file produced a similar result. TY J Quote Link to comment
Jonathan Pickup Posted September 27, 2010 Share Posted September 27, 2010 screen captures are 72dpi. when you export from Vectorworks there are a few choices. Did you use the batch render option? Quote Link to comment
JSiegel Posted September 27, 2010 Author Share Posted September 27, 2010 When displaying the camera view in the DL I select dpi of 300. The result is jagged in the DL. When I export the image as a .png/.tiff I choose 300 dpi and get a jagged image as well. When I create a SLVP of the rendered image the result is still jagged. I have changed the Sheet Layer to 300 dpi & attempted to render the image where i get the spinning clock (not even the beachball anymore) and ultimately abandon the render after 30 minutes. I did not use the batch render option. The screen shot at 72 dpi, is just slightly worse than the image I get on screen per the methods above? This is very frustrating. Are there some tried & true CRW settings that work for a simple exterior rendering like I am trying to produce? TY J Quote Link to comment
JSiegel Posted September 27, 2010 Author Share Posted September 27, 2010 After some experimentation. I rendered the image at 300 dpi in the SLVP, changed the Sheet layer dpi to 300 and got a decent image. Set my VW preferences 3D Conversion resolution to very high. Rendering took just over a half hour. TY J Quote Link to comment
