SHEET TITLE QUESTION
scottfdavis
Is it possible to have a multi-line category for the Sheet Title?
I am using a custom title block and have labeled the record format "SHEET TITLE_SD#"as instructed to get a multi-line entry field. When I use the Object Info window and select EDIT TITLE BLOCK I have a category that allows me to make a multi-line entry, however when I exit the edit window only the first line is displayed and the info I put on the second line is erased.
Is this a result of the automatic titleblock coordination features?
Does anyone know how I can make this work or do i need to add a second field for the second line of text in this particular case?
Thanks.
