SDK Trouble
Guest Mark Flamer
I have some tools I want to develop for VW. I have explored VS and am impressed with how simple the language is. Most of my programming experience is using C# and .net. I am considering using c++ and the SDK to develop my plugins. The switch from C# to C++ doesn't look too bad. Just have to get the hang of these header files, prototypes and pointers and I'll be in business. To get started I have installed VisualStudio C++ express 2005 but cannot get the sample file "Sample Object" to build. Does anyone have any idea why? I can provide more system info if necessary. Thanks. I just don't want to spend too much time in Vector Script only to find my self limited later.
Mark - I have been searching for another VW user using Windows 7 64 bit
If you have the time or inclination would you mind checking out this post
http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=29022&Number=142588#Post142588
There is an attachment of mine in first and last post - use the last one
Can you reproduce this on your puter
Thanks in advance if you get this!!
Darrell
Guest Mark Flamer
Darn, I was hoping for a responce. (: I will try and duplicate your behavior. I havent noticed any problems so far.
Guest Mark Flamer
Still stuck on getting started with the SDK. I have tried to open the sample solutions on a few machines running different versions of windows and Visual Studio. I get the same error each time.
The following error has occurred during XML parsing:
File: C:\Documents and Settings\Mark Flamer\Desktop\SDKVW1500(112122).Win\SDKVW1500(112120)\Source\Sample\SampleTool\SampleTool.vcproj
Line: 24
Column: 4
Error Message:
Property sheet file '..\..\..\..\Source\SDKLib\Include\OnlyWin\NNA_GlobalBuild.vsprops' was not found or failed to load.
The file 'C:\Documents and Settings\Mark Flamer\Desktop\SDKVW1500(112122).Win\SDKVW1500(112120)\Source\Sample\SampleTool\SampleTool.vcproj' has failed to load.
I'm not sure if this is a silly error on my part not being fully familiar with C++, or something else. I would really appreciate any help I can get. I'm confident that if someone could just point me in the right direction I could get productive pretty quick. Thanks.
Hi Mark, are you still fighting with this?
Anyway, open the cproj file as text file and change the path to NNA_GlobalBuild.vsprops, the correct one is:
..\..\..\SDKLib\Include\OnlyWin\NNA_GlobalBuild.vsprops
Regards,
Vlado
Guest Mark Flamer
Vladislav,
I had given up hope. I will try that. Thank you very much.
