monkey Posted July 6, 2010 Share Posted July 6, 2010 Hi can anyone help. i need to be able to plot points in VW using easting & northing UTM co-ordinates. i have a script that will give me the easting and northing of a point already plotted, but obviously this does not match the X & Y figures in the OIP. cant for the life of me figure out how to do this, surely it must be possible, am i being stupid or is it a bit harder than i think. Quote Link to comment
Miguel Barrera Posted July 6, 2010 Share Posted July 6, 2010 Are the easting and northing planar or radial(degrees) coordinates? If planar coordinates, they should be equivalent to the x (=Easting) and y (=Northing). If the points do not match, they may need to be rotated. If radial, you would need to translate the latitude and longitude (degree coordinates) to plane coordinates based on local criteria. This is typically done by GIS software. If you have the shape (.shp) and the projection (.prj) file for the points, you can import the shape file into VW and it will convert the points to plane coordinates. Quote Link to comment
monkey Posted July 7, 2010 Author Share Posted July 7, 2010 (edited) the points are not in degrees, they are 6 figure linear UTM ordnance survey coordinates. they dont match the x & y. struggling a bit with this one Edited July 7, 2010 by monkey Quote Link to comment
islandmon Posted July 7, 2010 Share Posted July 7, 2010 Try VW>Help>Survey Bearings: Quote Link to comment
monkey Posted July 7, 2010 Author Share Posted July 7, 2010 islandmon, you have lost me on that one, i have a 6 figure grid reference ie. E710546 & N530219 all i want to do is find some way to be able to punch these numbers in and a point be plotted, currently i cant do this by putting those numbers into X & Y in the OIP as they appear in the wrong place, i know this is the case as i have a georeferenced map in the file and they appear nowhere near it. maybe this just isnt possible Quote Link to comment
monkey Posted July 7, 2010 Author Share Posted July 7, 2010 forget it, iv worked it out, my bloody origin was way off from where it should be, seems to work fine now!!!! Quote Link to comment
