James W. Johnson
Organizing Sheets
Is there a quick and easy way to automatically number your sheets? I find that I add and delete sheets on a regular basis. Is there a way to re-order them without having to change each sheet number?
James, I have the same problem, my solution is waiting until the final revisions are done before completing the titleblock. The latest version of VW's has linked sheet numbers to section marks, however, you must use the section viewport feature for this to work. This does me no good because I use symbols from a large library I've created over the years, thus negating the need for the section viewport feature in VW's. I do this mostly because the section symbols in my library are already annotated which I find constitutes much of the work in creating quality sections.
