Door Texture Mapping
Is there a way to properly map a texture onto a door? I have a parametric door object which I have assigned the inner/outer leaf parts to a style class. When I assign a wood texture to the class it maps onto the door as vertical lines. I did a test with the same texture and extruded rectangle which was much more successful.
Thanks,
Kevin
