mpkeane Posted May 10, 2010 Share Posted May 10, 2010 I am working on a file that was initiated in VW12.5 and I am now working on it in VW2010. Suddenly most of the drawing on all layers went grey and will not respond to the cursor. It's almost like it everything is frozen in "Grey Others" layer option. All Layers and Classes are set to Show/Snap/Modify. A few random lines on certain layers respond to the cursor (can't determine any connection between them) but everything else is frozen. I shut down VW and restarted > no change. I shut down the computer and restarted > no change. What could be going wrong? Marc Quote Link to comment
mpkeane Posted May 10, 2010 Author Share Posted May 10, 2010 To answer my own question, I had inadvertently switched a main Class to the "Grey" mode of visibility. I didn't realize in the Grey visibility mode, the cursor doesn't react to objects. Don't know how I did that. I was fiddling with the arrow keys to move an object around the page at the time. I wonder if I accidentally pressed another key while using the arrow keys and inadvertently toggled the Visibility mode. Is that possible? Marc Quote Link to comment
Ray Libby Posted May 11, 2010 Share Posted May 11, 2010 All layer must be in Top/Plan view, NOT Top view. You probably switched the view on the layer by hitting "5" key. Quote Link to comment
