ChrisA Posted May 3, 2010 Share Posted May 3, 2010 how do i get a 3D object to render and look 2D in my drawings. I have placed a toilet in a bathroom and when i create an elevation of the toilet. it renders with all the lines that make up the 3D object. I am sure there is a simple solution but i am just not seeing it. Any help would be appreciated. Chris Quote Link to comment
Ray Libby Posted May 3, 2010 Share Posted May 3, 2010 Could you post an image showing it? Click on the Switch to Full Reply Screen button at the bottom and use File Manager to upload an image. You could also post the file for a quick solution. Quote Link to comment
J Lucas Posted May 3, 2010 Share Posted May 3, 2010 In a design layer use Hidden Line with the smoothing angle set to say 30 degrees. To set the smoothing angle see the drop down menu: View-Rendering-Line Render Options. Quote Link to comment
ChrisA Posted May 3, 2010 Author Share Posted May 3, 2010 Here is a picture of the elevation. thanks Quote Link to comment
J Lucas Posted May 3, 2010 Share Posted May 3, 2010 If the elevation above is a viewport, use viewport settings for Hidden Line rendering and smoothing angle. Quote Link to comment
ChrisA Posted May 3, 2010 Author Share Posted May 3, 2010 "I SEE" SAID THE BLIND MAN Quote Link to comment
