Assembly Posted April 16, 2010 Share Posted April 16, 2010 Here is a good one for you PIO developers. FindAndReplace will find all of an old PIO and insert a new version. It would be great if some one with a bit of dialog experience could wrap one around this.... PROCEDURE SHELL; {*/ This Procedure will searh a file and upgrade all instances of a PIO It can be used for PIO's that have the same parameter Names **} PROCEDURE FindAndReplace(oldPIOName:String;upgradeName:String); PROCEDURE FindReplace(hObject:Handle); VAR x1,y1:Real; hLayer:HANDLE; LayerName: STRING; NewObject: Handle; hNewObject:Handle; recName:String; recHand:Handle; Cnt:INTEGer; fldName:STRING; PassText:String; BEGIN; GetSymLoc(hobject,x1,y1); {*/Get insert point of existing PIO} hLayer:=GetLayer(hObject); LayerName:=GetLName(hLayer); Layer(layerName); {*/Change to the layer of the Existing PIO} hNewObject:= CreateCustomObjectN(upgradeName,x1,y1,0,False); {*/Inserts the new Object over the old one} recName := GetName(GetRecord(hObject, NumRecords(hObject))); {*/Get Record Name of existing PIO-This is entered anyway} recHand := GetObject(recName); {*/Get Handle to Record} FOR cnt := 1 TO NumFields(recHand) DO BEGIN {*/For each of the parameters in the object} fldName := GetFldName(recHand, cnt); {*/Get the Parameter Name} PassText:=GetRField(hObject,recName,fldName); {*/ Get the Value} SetRField(hNewObject,upgradeName,fldName,PassText); {*/ Pass the Value into the Parameter of the New Object} END; END; Begin; ForEachObject(FindReplace, INSYMBOL & INOBJECT & INVIEWPORT & (PON=oldPIOName)); END; BEGIN; FindAndReplace('NZ Master Spec Note','NZ Master Spec Legend'); END; Run (SHELL); {Code Written By Justin Wright 2010} {This program is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with this program. If not, see .} Quote Link to comment
