td4stage Posted September 26, 2001 Share Posted September 26, 2001 When I dimension an object, for me to confirm to dimension I need to zoom in so I can actually read the numbers. Is there a place to see the dimension text without having to zoom in on the actual dimension Patrick Immel Northwest Missouri State University Quote Link to comment
Ken Posted September 27, 2001 Share Posted September 27, 2001 Have you tried the Measure tool? Its accuracy setting can be set (in the Units dialogue) higher than the dims, and you simply read it off the Data bar. Measure from dim extension line to the other dim extension line. Quote Link to comment
rcarch Posted September 27, 2001 Share Posted September 27, 2001 dont try the measure tool in 9.0.1 - it is very buggy - try setting your default text to a larger size Quote Link to comment
td4stage Posted September 27, 2001 Author Share Posted September 27, 2001 Could the dimension text be displayed in the OI pallette? (Should I post this in the wish list section as well?) Thanks Quote Link to comment
