Doug L Posted November 5, 2009 Share Posted November 5, 2009 How do you rotate a hatch pattern? Checking and unchecking Rotate In Wall and Rotate in Symbol in Edit Hatch had no effect. I found these web instructions: at: http://download2cf.nemetschek.net/www_misc/2010/Vectorworks%202010%20Help/Data/15_Vectorworks/07_ImageGradFills/Editing_Hatch_Fills.htm 1. Click the Attribute Mapping tool from the Basic or Visualization tool set. 2. Click on an object containing an associative hatch fill. Only one object at a time can be edited. 3. An editing object with eight handles is placed over the hatch. The hatch origin is at the lower left corner of the editing object, where the red and green lines meet. However, item #3 doesn't happen. Is this only a feature of VW 2010 and not 2009? Is there another way? Its a rectangular shaped stone pattern and I need it to align with a plaza that is not true north. Quote Link to comment
Ray Libby Posted November 5, 2009 Share Posted November 5, 2009 Sorry, this is new in VW 2010. Quote Link to comment
M5d Posted November 10, 2009 Share Posted November 10, 2009 Yes there is another way. Select a polygon or group of lines that enclose an area and then select the hatch command from the modify drop down menu, you can then set the base point and angle as part of the command. Quote Link to comment
