Tmonson Posted October 13, 2009 Share Posted October 13, 2009 So I'm curious if anyone else has discovered this same issue I've found. When assigning multiple accessories to a fixture in VW2010(i.e. scroller and top hat) you can't move these accessories independently of each other. Once plotted they act as a group. It hasn't been a problem for me while drafting plots but when using LW5 to add accessories at focus, etc it does it's best to plot the 'added' accessory to the fixture in the VW file but it typically needs to be moved to line up with the fixture the added accessory is associated..thus causing any accessories already associated with that fixture to move as well. Has anyone else found this and if so discovered a workaround? Tim Quote Link to comment
