Tmonson
    2
Everything posted by Tmonson
  1. Geoff- I'd agree with Shelley that your root symbols are likely inadvertently comprised of multiple classes. An easy fix if that is the issue rather than editing/checking each symbol try this: Create a new class...i.e 'lighting instruments' Group all your lighting symbols together in one folder and use the Tools/Utilities/Change Symbol Atts to make all your root symbols now in the 'lighting instruments' class. Hopefully, that should solve the problem of symbols being comprised of different classes. Tmonson
  2. So I'm curious if anyone else has discovered this same issue I've found. When assigning multiple accessories to a fixture in VW2010(i.e. scroller and top hat) you can't move these accessories independently of each other. Once plotted they act as a group. It hasn't been a problem for me while drafting plots but when using LW5 to add accessories at focus, etc it does it's best to plot the 'added' accessory to the fixture in the VW file but it typically needs to be moved to line up with the fixture the added accessory is associated..thus causing any accessories already associated with that fixture to move as well. Has anyone else found this and if so discovered a workaround? Tim
