REB Posted August 8, 2009 Share Posted August 8, 2009 I have a S4 that without a gobo lights the object it's focused at (established by a focus point) but once I edit the Light Info, Gobo 1, get resource, and select a VW provided gobo texture, the light renders nothing, as if it weren't on (though it still is). Took out the gobo, the light returned, put it back in, no more light. I'm using Final Quality and tried Custom as well. Ray Traced Shadows is selected and all seems normal, (other than the lack of gobo projection) I've simplified everything I can to locate the problem, but no dice. I've even tried it with a new blank document, bare bones. Same results. Quote Link to comment
cad@sggsa Posted August 11, 2009 Share Posted August 11, 2009 Which version of VW are you on. Please post it in your signature along with your OS etc. Quote Link to comment
