IvanAriel Posted June 13, 2009 Share Posted June 13, 2009 Hi everyone! This is my first post, I have been this script for several time. Basically this script does is to join a set of Polys consecutively(join poly 1 with 2,3,4,5). The problem now is that I need to modify this script to join the poly 1,3,5.Someone can help me with this please Thank you in advence The Script: Procedure TheProcedure; {debug} VAR x,y,d: REAL; r, g, b :LONGINT; h,h1: HANDLE; s: STRING; i,j,n,vtx,m,ii,i2: INTEGER; p1,p2: POINT; Myp,Myp2: DYNARRAY OF POINT3D; {----------------------------------------------------------------------} Procedure DrawPol(Myp: DYNARRAY of POINt3D;i:INTEGER); VAR h1,h:HANDLE; j:INTEGER; BEGIN layer ('new Lines'); OpenPoly; BeginPoly; For j:=1 To i do BEGIN IF Myp[j].z=0 Then Addpoint(Myp[j].x,Myp[j].y); IF Myp[j].z=1 Then CurveTo(Myp[j].x,Myp[j].y); IF Myp[j].z=2 Then CurveThrough(Myp[j].x,Myp[j].y); END; EndPoly; h1:=LNewObj; ColorIndexToRGB(7, r, g, b); SetPenFore(h1, r, g, b); SetFPat(h1,0); layer(s); END; {----------------------------------------------------------------------} {----------------------------------------------------------------------} Procedure Del_Points(Myp: DYNARRAY of POINt3D;i:INTEGER; Dist: REAL; Dist2: REAL; VAR Myp2: DYNARRAY of POINt3D; VAR jj: INTEGER ); VAR d: REAL; j: INTEGER; BEGIN jj:=1; FOR j:=1 TO i-1 DO BEGIN d:= Sqrt (Sqr((Myp[j+1].x-Myp[j].x))+Sqr((Myp[j+1].y-Myp[j].y))); IF MyP[j].z>0 THEN BEGIN IF d>dist THEN BEGIN MyP2[jj]:=MyP[j]; jj:=jj+1; END; END ELSE BEGIN IF d>dist2 THEN BEGIN MyP2[jj]:=MyP[j]; jj:=jj+1; END; END; END; MyP2[jj]:=MyP; END; {----------------------------------------------------------------------} Procedure FindP(x,y : REAL;h: HANDLE; VAR ii: INTEGER; VAR xp,yp : REAL); VAR x1,x2,y1,y2,dst1,dst2: REAL; i: INTEGER; BEGIN i:=GetVertNum(h); GetPolylineVertex(h,1,x1,y1,vtx,d); dst1:= Sqrt( Sqr(x1-x) + sqr(y1-y) ); GetPolylineVertex(h,i,x2,y2,vtx,d); dst2:= Sqrt( Sqr(x2-x) + sqr(y2-y) ); IF dst1>dst2 THEN BEGIN xp:=x2; yp:=y2; ii:=i; END; IF dst1 xp:=x1; yp:=y1; ii:=1; END; END; {----------------------------------------------------------------------} BEGIN h:=ActLayer; s:=GetLName(h); n:=NumSObj(h); h:=FSActLayer; GetPt(x,y); ii:=1; FindP(x,y,h,ii,x,y); FOR m:=1 TO n DO BEGIN i:=GetVertNum(h); ALLOCATE Myp[1..i+1]; ALLOCATE Myp2[1..i+1]; IF ii=1 THEN BEGIN FOR j:=1 TO i DO BEGIN GetPolylineVertex(h,j,Myp[j].x,Myp[j].y,Myp[j].z,d); END; END; IF ii=i THEN BEGIN FOR j:=1 TO i DO BEGIN GetPolylineVertex(h,i+1-j,Myp[j].x,Myp[j].y,Myp[j].z,d); END; END; h1:=NextSObj(h); IF h1<>NIL THEN BEGIN i:=i+1; FindP(Myp[i-1].x,Myp[i-1].y,h1,ii,Myp.x,Myp.y); Myp.z:=0; END; Del_Points (Myp,i,.2,.2,MyP2,i2); DrawPol(Myp2,i2); h:=NextSObj(h); END; layer ('new Lines'); END; RUN (TheProcedure); Quote Link to comment
islandmon Posted June 13, 2009 Share Posted June 13, 2009 I'm not an expert on any of this .. but it seems that Set Theory would be invaluable. Thus avoiding the inherent recursion problem: { Criteria Set Procedure } { If > Criteria > Then > Set If > Set > Then > Procedure If > Procedure > Then > Set } Quote Link to comment
ccroft Posted June 13, 2009 Share Posted June 13, 2009 Hi Ivan, I'm not currently some place where I can actually run this script to see it in action, and my knowledge of poly drawing isn't good enuf that I can visualize what you're doing. So a couple of questions: The script works on a set of selected objects, correct? Why can't you just select objects 1,3,5 instead of objects 1,2,3,4,5? Do you still need to join 1,2,3,4,5 but process them in a different order? "to join a set of Polys consecutively.." I don't see something that determines the order in which the objects are processed. As written it would seem to be by stacking order...the order in which they are drawn. It's entirely possible that I'm just missing this part (the ordering), so if it's there please point it out. That's to say how is 'consecutive' determined? Quote Link to comment
IvanAriel Posted June 13, 2009 Author Share Posted June 13, 2009 Hi, thank islandmon and ccroft for reply my question. ccroft, you are right, I can select objects 1,3,5 and then join them, but the problem is that I work between 700 and 1000 polys. At the moment I am selecting poly 1,3,5 to 700...this job take me around 3 or 4 hours. This is the reason because I want to change the script..select all of them and then only join objects 1,3,5,7.. You can see how it works, drawing a few polys, select all, click "Alternate Line" and click in the right or left side of the polys. Please let me know if I am clear with this script. Thank you again for your time Quote Link to comment
ccroft Posted June 14, 2009 Share Posted June 14, 2009 I've never tried this, but if you want to skip every other poly it would seem to be simply a matter of repeating: "handle:=NSObj(handle)". h:=FSActLayer; gets handle to #1 (in your script) h1:=NextSObj(h); gets handle to #2 (in your script) h1:=NextSObj(h1); should get handle to #3 (add to script right after above) And then towards the end you need to iterate h to #3 handle before going thru the 1st loop again: replace h:=NextSObj(h); (in your script) with h:=h1; (The way I read it, "h:=NextSObj(h);" is the same as saying "h:=h1".) The next time thru the main loop: h1:=NextSObj(h); gets handle to #4 (in your script) h1:=NextSObj(h1); should get handle to #5 I still can't test this and there may be something wrong with my thinking. If that's true I'd be happy to have it pointed out, but it seems to me that something along these lines should work. Quote Link to comment
ccroft Posted June 14, 2009 Share Posted June 14, 2009 Ivan, After reading my post it occured to me that it might be clearer to simply show how I was thinking of changing the script: IF ii=i THEN BEGIN FOR j:=1 TO i DO BEGIN GetPolylineVertex(h,i+1-j,Myp[j].x,Myp[j].y,Myp[j].z,d); END; END; h1:=NextSObj(h); h1:=NextSObj(h1);???????????????{added to original script} IF h1<>NIL THEN BEGIN i:=i+1; FindP(Myp[i-1].x,Myp[i-1].y,h1,ii,Myp.x,Myp.y); Myp.z:=0; END; Del_Points (Myp,i,.2,.2,MyP2,i2); DrawPol(Myp2,i2); h:=h1;??????????????????????????????{change from original} END; layer ('new Lines'); END; And as I said before there's very likely a glaring flaw in my logic... Quote Link to comment
ccroft Posted June 14, 2009 Share Posted June 14, 2009 Sooo.....later that day: Got to a machine w/ vWorks installed and played with the script. The above seems to work in terms of skipping every other poly. But it fails due to the first FOR loop in the main block. As written the script counts the number of selected objects and executes the loop that many times. But with the above changes we're skipping objects, so the loop keeps going after the last selected poly has been processed. It gets NIL handles to non-existent objects and spews out faulty data leading to various errors. The solution seems to be a WHILE loop instead. You can skip the counting part entirely. The loop keeps executing until it gets a NIL handle....IE until it processes the last selected object. Here's the re-written main block: BEGIN h:=FSActLayer; GetPt(x,y); ii:=1; FindP(x,y,h,ii,x,y); WHILE h<> NIL DO BEGIN????????{was the FOR loop} i:=GetVertNum(h); ALLOCATE Myp[1..i+1]; ALLOCATE Myp2[1..i+1]; IF ii=1 THEN BEGIN FOR j:=1 TO i DO BEGIN GetPolylineVertex(h,j,Myp[j].x,Myp[j].y,Myp[j].z,d); END; END; IF ii=i THEN BEGIN FOR j:=1 TO i DO BEGIN GetPolylineVertex(h,i+1-j,Myp[j].x,Myp[j].y,Myp[j].z,d); END; END; h1:=NextSObj(h); h1:=NextSObj(h1); IF h1<>NIL THEN BEGIN i:=i+1; FindP(Myp[i-1].x,Myp[i-1].y,h1,ii,Myp.x,Myp.y); Myp.z:=0; END; Del_Points (Myp,i,.2,.2,MyP2,i2); DrawPol(Myp2,i2); h:=h1; END; layer ('new Lines'); END; RUN (TheProcedure); Hope that works for you. Quote Link to comment
IvanAriel Posted June 15, 2009 Author Share Posted June 15, 2009 Hi ccroft, thank so much for you help, the script is working perfect!!. I have been trying to do this for 2 weeks...and nothing.. Thank you again Charles. Ivan Quote Link to comment
ccroft Posted June 16, 2009 Share Posted June 16, 2009 Happy to hear it worked out for you Ivan. Thanks for posting back. (finally.... beat Stanford to the punch...must've been climbing a mountain or something :-) Quote Link to comment
IvanAriel Posted June 23, 2009 Author Share Posted June 23, 2009 Hi Charles, Could you help me one more time? I am working with polygons of 4 colours (red, blue, yellow and green) and the script palette of 4 colours. When I click on the red (in the palette) selects all polygons red, and so in this way with the other colours. My question is: in the same way that I work with the colours, how I can select the odd polys and the pairs polys using the script pallet? The function is the same that the other script, but in this case I do not need join them, just select them (odd and pairs) Script: Blue: DSelectAll; SelectObj((PF=4)); Red: DSelectAll; SelectObj((PF=7)); Yellow:DSelectAll; SelectObj((PF=5)); Green:DSelectAll; SelectObj((PF=6)); Thank in advance Quote Link to comment
ccroft Posted June 24, 2009 Share Posted June 24, 2009 Hi Ivan, This may work for you: Procedure SelectEveryOther; VAR h: HANDLE; BEGIN h:=FSActLayer; h:=NextSObj(h); WHILE h<> NIL DO Begin SetDSelect(h); h:=NextSObj(h); h:=NextSObj(h); End; END; RUN (SelectEveryOther); Quote Link to comment
IvanAriel Posted June 24, 2009 Author Share Posted June 24, 2009 Hi Charles, Again.... thank you very much for your help. The Script is working!!. Thank you!! Ivan Quote Link to comment
