MaxStudio Posted April 22, 2009 Share Posted April 22, 2009 I want to enable certain items when a check box is checked. I figured something like the following would suffice: IF ItemSel(5) THEN SetItemEnable(8,TRUE); or IF ItemSel(5) THEN BEGIN SetItemEnable(8,TRUE); SetItemEnable(9,TRUE); SetItemEnable(10,TRUE); END; I've also tried the following: IF ItemSel(5) THEN check01:= 1 ELSE check01:= 0; IF (check01=1) THEN SetItemEnable(8,TRUE); I can't seem to get any of these to work. Maybe I'm entering the code in the wrong place? I am using modern dialogs. Below is the Dialog I am trying to fit this code into: PROCEDURE Drive_Dialog(VAR item:LONGINT; data:LONGINT); VAR cstr: STRING; BEGIN CASE item OF SetupDialogC: BEGIN { Pulldown Menu 1 } InsertChoice(18,4,'1/4"'); InsertChoice(18,0,'1/32"'); InsertChoice(18,1,'1/16"'); InsertChoice(18,2,'1/8"'); InsertChoice(18,3,'3/16"'); InsertChoice(18,5,'3/8"'); InsertChoice(18,6,'1/2"'); InsertChoice(18,7,'3/4"'); InsertChoice(18,8,'1"'); InsertChoice(18,9,'1/1/2"'); InsertChoice(18,10,'2"'); InsertChoice(18,11,'3"'); InsertChoice(18,12,'1"=10'); InsertChoice(18,13,'1"=20'); InsertChoice(18,14,'1"=30'); InsertChoice(18,15,'1"=40'); InsertChoice(18,16,'1"=50'); InsertChoice(18,17,'1"=100'); { Pulldown Menu 2 } InsertChoice(20,4,'1/4"'); InsertChoice(20,0,'1/32"'); InsertChoice(20,1,'1/16"'); InsertChoice(20,2,'1/8"'); InsertChoice(20,3,'3/16"'); InsertChoice(20,5,'3/8"'); InsertChoice(20,6,'1/2"'); InsertChoice(20,7,'3/4"'); InsertChoice(20,8,'1"'); InsertChoice(20,9,'1/1/2"'); InsertChoice(20,10,'2"'); InsertChoice(20,11,'3"'); InsertChoice(20,12,'1"=10'); InsertChoice(20,13,'1"=20'); InsertChoice(20,14,'1"=30'); InsertChoice(20,15,'1"=40'); InsertChoice(20,16,'1"=50'); InsertChoice(20,17,'1"=100'); { Pulldown Menu 3 } InsertChoice(22,4,'1/4"'); InsertChoice(22,0,'1/32"'); InsertChoice(22,1,'1/16"'); InsertChoice(22,2,'1/8"'); InsertChoice(22,3,'3/16"'); InsertChoice(22,5,'3/8"'); InsertChoice(22,6,'1/2"'); InsertChoice(22,7,'3/4"'); InsertChoice(22,8,'1"'); InsertChoice(22,9,'1/1/2"'); InsertChoice(22,10,'2"'); InsertChoice(22,11,'3"'); InsertChoice(22,12,'1"=10'); InsertChoice(22,13,'1"=20'); InsertChoice(22,14,'1"=30'); InsertChoice(22,15,'1"=40'); InsertChoice(22,16,'1"=50'); InsertChoice(22,17,'1"=100'); { Pulldown Menu 4 } InsertChoice(24,4,'1/4"'); InsertChoice(24,0,'1/32"'); InsertChoice(24,1,'1/16"'); InsertChoice(24,2,'1/8"'); InsertChoice(24,3,'3/16"'); InsertChoice(24,5,'3/8"'); InsertChoice(24,6,'1/2"'); InsertChoice(24,7,'3/4"'); InsertChoice(24,8,'1"'); InsertChoice(24,9,'1/1/2"'); InsertChoice(24,10,'2"'); InsertChoice(24,11,'3"'); InsertChoice(24,12,'1"=10'); InsertChoice(24,13,'1"=20'); InsertChoice(24,14,'1"=30'); InsertChoice(24,15,'1"=40'); InsertChoice(24,16,'1"=50'); InsertChoice(24,17,'1"=100'); END; 1:BEGIN Elev01:=GetField(7); Elev02:=GetField(10); Elev03:=GetField(13); Elev04:=GetField(16); DNum01:=GetField(26); DNum02:=GetField(28); DNum03:=GetField(30); DNum04:=GetField(32); IF ItemSel(5) THEN Check01:= 1 ELSE Check01:= 0; IF ItemSel(8) THEN Check02:= 1 ELSE Check02:= 0; IF ItemSel(11) THEN Check03:= 1 ELSE Check03:= 0; IF ItemSel(14) THEN Check04:= 1 ELSE Check04:= 0; IF (check01=1) THEN SetItemEnable(8,TRUE); GetSelChoice(18, 0, gScale01, cstr); GetSelChoice(20, 0, gScale02, cstr); GetSelChoice(22, 0, gScale03, cstr); GetSelChoice(24, 0, gScale04, cstr); END; END; END; BEGIN g_ID:= Define_Dialog; IF VerifyLayout(g_ID) THEN BEGIN g_Result:=RunLayoutDialog(g_ID,Drive_Dialog); Quote Link to comment
Miguel Barrera Posted April 22, 2009 Share Posted April 22, 2009 You are missing the code for each item in the case statement. Whenever you click on an item, the case statement gets executed and looks for that item number (i.e. 5,8,11 or 14) in the case statement. In your code, you are only handling calls to the setup and item 1, which is the OK button. You need to structure the code something like this: CASE item OF SetupDialogC: BEGIN .... END; 1: BEGIN ... END; 5: BEGIN IF ItemSel(5) THEN Check01:= 1 ELSE Check01:= 0; IF (check01=1) THEN SetItemEnable(8,TRUE); END; 8: BEGIN IF ItemSel(8) THEN Check02:= 1 ELSE Check02:= 0; END; 11: BEGIN IF ItemSel(11) THEN Check03:= 1 ELSE Check03:= 0; END; 14: BEGIN IF ItemSel(14) THEN Check04:= 1 ELSE Check04:= 0; END; END; Quote Link to comment
MaxStudio Posted April 22, 2009 Author Share Posted April 22, 2009 WONDERFUL THANK YOU MIGUEL! Ive gotten a test to work. This part of the dialogs has always confused me. So the number before the ":" such as "5:" is significant to which dialog item is being referenced? Quote Link to comment
Miguel Barrera Posted April 23, 2009 Share Posted April 23, 2009 Yes, that is correct. The numbers in the case statement correspond to the item number. You should have a number for each item that will trigger an action after the user clicks or enters text in the dialog item. Quote Link to comment
