mr. iagea Posted March 4, 2009 Share Posted March 4, 2009 Whenever I bring an interior wall to a wall that is styled as an exterior wall, and this join needs to happen on a corner, I cannot join the walls properly. Wall joins don't work. Fix wall breaks doesn't work. Anyone have this issue? Fix? (see attached images) Thanks! Quote Link to comment
gmm18 Posted March 4, 2009 Share Posted March 4, 2009 In this case I just join the two exterior walls... the interior wall is then just lined-up right where it needs to go, but it is not actually 'joined.' It is not a perfect solution, but works okay. Quote Link to comment
Chad McNeely Posted March 4, 2009 Share Posted March 4, 2009 L-join the exterior walls, fix your drafting error/misaligned interior wall, then T-join the interior wall to the exterior wall. Do some component joining if you feel like it, it'll work in about half the cases (where there isn't some other Y-join if I recall). And the L/T-joined combo will likely need to be redone several times over the course of the drawing's lifespan, since it comes undone fairly easily. Quote Link to comment
mr. iagea Posted March 4, 2009 Author Share Posted March 4, 2009 ah, that works. I wasn't L-joining the exterior wall first, because it was already joined...in that, it was already a continuous wall. thanks for your help, Chad! Quote Link to comment
