Assembly Posted March 3, 2009 Share Posted March 3, 2009 I'm writing a script for ProfiledMetalSection The width of sheet of profile metal always ends with the trapazoid coming down. Hence the length is determined by the profile shape. I'm using a linear tool so I can stretch the line to the desired length, but I want the code to then set the actual length that works for the profile. I need to be able to use the value to then reset the linelength parameter of the PIO. Quote Link to comment
ccroft Posted March 4, 2009 Share Posted March 4, 2009 You can probably do it in much the same way you were setting the child-object's params from the parent object in your earlier post, but using the handle & name from getcustom. getcustomobjectinfo(PIOname,PIOHandle,PIOrecordhandle,PIOwallhandle); SetRField(PIOHandle, PIOname,'pLineLength',newLineLength); Quote Link to comment
